Head Gasket surfaces - FirebirdV6.com/CamaroV6.com Message Board
  • Head Gasket surfaces
    How clean do these have to be? Does anyone have a picture of a clean head gasket surface? what is acceptable?
    I have removed all the gasket but I still see imprints and such of where the gasket used to be. I cant tell if its gasket or not. The surface feels really smooth. But I do also have some rust spots towards the bottom of where the gasket was. What is the best way to get these rust spots down smooth? I was told a emry cloth will work. And would it be a good Idea to use a reconditioning disc on the top of the piston to clean off all the rust?
    Don't worry about cleaning the pistons, but you need to clean the headgasket surface *as best as you can* to get it to fit snugly and not blow.
    I recommend emory cloth to lightly sand down all the stuff that is on there. You don't want a blown headgasket 1500 miles from now.
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
