how much is it for an L67? l67 i the same as L36 but forged right? crank balanced 50%(why not go 100% i dont know about this stuff so bare with me, im learning)
how much for gtp rods or regular forged rods.
how much for diamond plated pistons?
why not just go regular forged?
what is the difference, all details please
clevite 77 or? bearings, how much are they
thanks for the info guys.
96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
2004 GTP rod: i got mine from 3800 for 240 for all 6, they are forged.
i know AMM is working w/Manly for forged rods not sure on price but buy looking at the 3.4 rods there not cheap (500-800 for a set)
Diamond coated pistons are $879, that include pins and rings
go with Clevite 77, $69 for main bearings and $3 each for rod (need 6)
SSM has a lower end package for us now for 1050 (i think) all forged
i think when the crank is blanced to 50%, from my understanding that means that each side of the motor is balaced out perfect, so the rod/piston crank on the drive side bank is the same or vary vary close to the pass bank. this lets you rev higher and make the motor more stable
Andrew
www.turbov6camaro.com 1997 3800 Series II Camaro 4600 Stall for my ride to the mall :chug: 7.18 @ 99.77 1/8 -1.8x sixty (current quickest v6 fbod) 11.23 @ unk 5 1/4 - 7.19 1/8 - 1.83 sixty
Originally posted by Die Ford V8: does the kit from ssm have all that you listed or what is the difference? thanks for the info man. ur a big help
The kit he sales is for the ford 3.8's. He says he can make a kit for gm 3.8's for around the same price.
"That is for fords only, but, we can can put a kit together using race-prepped stock rods and custom Wiseco forged pistons for the same price. The stock GM3800 rod is pretty stout, it just needs beam polishing, shot peening, and some good ARP rod bolts, and its already uses a bushed pin, so the pistons would be setup for bushed installation with spiro-lox. We can set the compression ratio with the piston from 8.5 to 10.5: depending on your application."
what is the site for ssm, that seems like a deal to get a lower end built up.
what is their email address?
not alot of links on their site work for me..
- \"So you have something to look at when you\'re talking to \'em\" - <br /> <a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=296916\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=296916</a>
like i said, it comes up with a site not responding.....
