Originally posted by AZ3.8Camaro: </font><blockquote>quote:</font><hr />Originally posted by kamarozrule: r u sure its not an LS1... thats a nice cam how much did it cost?
It was $315 for the cam, buy the time I bought all of the gaskets and other things I replaced, it was closer to $600 or more..
sounds great. I see 13.8 in your sig. was that before or after the cam? what track do you run at? great car. Also I thought that the LS1 valve springs wouldnt work on our cars?
2002 A4 Pewter Firebird.<br />Aluminum interior, custom aluminum whisper lid, custom ram air, Flowmaster cat bacl, high flow cat, pacesetter headers<br />15.018 on a ****ty track<br />15.65 stock on same ****ty track<br />15.33 stock on good track<br />= 14\'s on good track
Originally posted by CorbinWelter: does anybody know if the GT2 cam has more lobe then this 4x4 cam, or if it has any where near the same torque?
It will lope a little more due to the tighter 111 lsa Otherwise, it's the identical lobe from Comp Cams.
This topic never dies.
Timbo is right.
If you want to buy the identical cam I have, you need to call comp directly. (IE go to their website, get the number and call.)
1997 Dodge Viper GTS
that better be an old camaro [img]graemlins/rock.gif[/img] and not some ford [img]graemlins/slap.gif[/img] lol
1995 black firebird,t-tops,3.4L M5 Comp cam,gutted cat,Cold Air,80 series flowmaster,limited slip rear end with 3.42 gear, Hurst Billet Plus, 17\" American Racin Torq Thrust II
Originally posted by Fear_Factor: that better be an old camaro [img]graemlins/rock.gif[/img] and not some ford [img]graemlins/slap.gif[/img] lol
Its a 3.8 from my 1997 camaro.
Driveability is fine. The car shakes at idle, but never dies or stalls. Gas mileage is about the same as stock, maybe some less, but its hard to tell because I drive it harder now anyways! :D
