3.8L power pack - FirebirdV6.com/CamaroV6.com Message Board
3.8L power pack
  • 3.8L power pack
    just recently stumbled on this. any opinions on this? what kind of gain, and how much install cost is it gonna run? anything i should get so the car can "handle" it?(ie. sfc's?)
    tanks guys.... lots of tanks
    - \"So you have something to look at when you\'re talking to \'em\" - <br /> <a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=296916\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=296916</a>
    Search....
    Powerpack cost about $2,000, install around another $1,000 unless you do it yourself.
      they say that on a stock car, flywheel hp will go up to 275 w/ heads/cam. for traction, LSD, 3.23's or 3.42's, and tires will work well w/ it. I suggest 255-50-ZR16 kumho ecsta supra 712's. If you get wheel hop after this, lca's and 1LE swaybars will fix the wheel hop. You'll get more out of the power pack if you do intake mods and exhaust mods, mainly whisper lid, filter, cat-back, cold/ram air, and removed maf screen. You already have most of the intake/exhaust done, so you'll be making some good power. The good thing about chassis stiffening parts is that you feel less bumps in the road, giving you a better ride quality. A stb and sfc's will make the suspension take in more road irregularities. A MSD-DIS-4, Accel ignition packs, wires, and spark plugs will take care of lighting off the increased air/fuel mixture.
        whoa, where can I find more info on this power pack?
          Like stated above, use the search function. search the advanced tech forum. Or goto www.supersixmotorsports.com
          basically its a port and polished intake manifolds, heads, and cam. Cost $2,000. Not much more too it. Check out his website then search and if you still have questions then post.
            i think im gonna go for it..... enxt spring, not many mods i can show off during the winter, but its do-able
