will these work, the guy on ebay says that he replaced all o rings and filters. i think these sound good. My other question is, i heard some guys say that 19lb are what i need after a cam, and custom intake, but others say they ran rich with 19's, and put their stock 17's back in. should i just bump up the fuel pressure with the holley Adjustable air fuel pressure regulator? thanks eric
Ford Mustang 5.0 injecters ok for 3.4 Camaro?
This topic is closed.
With the stock 17lb injectors I ran lean at high RPMs. I now run the 19lb Ford Motorsports injectors and they run fine.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
Originally posted by IMTHEPUNISHER:
Well, 1st off...if U mispell the word "Injectors"...U probably shouldn't even NEED 2 ask. Heh heh hehMatt
1998 Mystic Teal Camaro M5
Probably shouldn't need to ask what, dumb$h!t? We have an grammar guru in the house. I posted late last night, while studying for finals, so I'm not quite sure what you are suggesting, but I carry a 3.8 GPA at the University. Second, if you can't answer my question because you lack knowledge and experience, then don't take up space and even reply. I mean it's not that hard, the format goes Question:, Answer. Not Question, Ignorant irrelevant reply. BACK OFF punk.
