Alright, so I bought this 95 3.4 and have a question... not all too familiar with how some valvetrain effects each other.
I ordered the comp cams x-kit with the 260 duration cam and the magnum roller rockers with 1.6 ratio and energy pushrods... now...
1. are these fully compatible?
2. I dont need to make any other alterations going from a 1.5 ratio to a 1.6?
also, I am getting a shop to bowl blend and port match everything, as well as do a 3 angle valve job and back-cut the valves.
3. Are my stock valves still good or should I order some new OEM replacements?
4. is there another larger valve that would be compatible and give me a better performance?
thanks, I appreciate your help with these 4 questions.
