Crower cam - FirebirdV6.com/CamaroV6.com Message Board
Crower cam
  • Crower cam
    Well i have just recently become friends with the owner of crower and he said that he can get me any cam that i want for dirt cheap. So my question to you is what is the best crower cam to get for my car if my goal is low 14s? Which one is the best for me? And should i throw in for some springs? If you could give me the part number that would be really cool.
    2002 M5 camaro- VTR CAI, custom cat-back exhaust, battery compacitor, pullie, lowering springs, 32mm sway bar, cross-drilled slotted rotars. 1-10\" L7 in cubby.
    Tell him 210/210 .317/.317 112lsa 108ic .507/.507. That cam will get you where you want to be, and not set off any codes, except may be a little false knock, all you have to do is desensitize the knock sensors and you are done..
      thats kind of a mild grind. It should get you in the 14 second range like you want though.
