I have a question on how to remove the regulator housing from the fuel rail? I noticed the screws are a hex or star-shape,~but with a small center pin set in the center.
-do you file that center pin out?
-what size or name of the tool to use to unscrew them?
---94 Camaro-L32--- <br />\"Don\'t hate the playr, Hate tha GAME!!\" <a href=\"http://members.cox.net/jeanda_sd/SD_L32/SD300L32.jpg\" target=\"_blank\">http://members.cox.net/jeanda_sd/SD_L32/SD300L32.jpg</a> <br /> <a href=\"http://members.cox.net/jeanda_sd/SD_L32/100_0022.JPG\" target=\"_blank\">http://members.cox.net/jeanda_sd/SD_L32/100_0022.JPG</a> <a href=\"http://members.cox.net/jeanda_sd/SD_L32/L32flipmode.wmv\" target=\"_blank\">http://members.cox.net/jeanda_sd/SD_L32/L32flipmode.wmv</a>
those are tamper proof torx bits... you can usually find the correct socket at an auto parts store or any place that sells decent tools. just look for the torx bits that have the hole drilled in them.
