Well car started off runing darn good when i first installed the heads and cam.
Then i install a 3800 stall and i started to get some nasty KR and ran me a best of 15.2@86 mph.
I installed some resisters on the knock sensors and car ran great for like 4 days.
So i started to spray on the street again just a 50 shot and car ran good.
Well two days before my dyno day car started misfireing so on the dyno day i did a wire change and i didnt see any misfires on the dyno so thats good.
Dyno numbers were ok NA.
Before heads and cam with a 3000 stall and 3.42 gears.I dynoed
164hp with 232 TQ.
Weeks later i ran my 14.34@91mph
Now with heads and cam and 3800 stall and unprogramed 3.73's
195hp no TQ showed up
This is only running the car to 5500 rpms cause of the unprogramed gears. Whice is a 31 hp gain.
Well i had him make one dyno pass on the 100 shot. I used a rich jet so i wouldnt go lean and the bottle was cold only like 700 psi and it was like 105 outside.
264 and no TQ reading
dyno graph looks funny for the nitrous run.
Well about two days later the car started misfiring again with no bad plugs or wires and coil packs look clean. Then the next day i started burning oil. I can smoke up an entire stoplight.
Now performance has really dropped off. I am being told it is one of two things from some people i know. It is a valve that is stuck or no sealing or piston ring is gone. Let me know if yall have any suggestions.
164hp with 232 TQ.
