ok, i've been searching for this for a bit but havent found a decent answer. for a performance buildup, is a high volume oil pump necessary or is it just eating up extra hp? mine entire engine is going to be rebuilt and right now i'm all but set on a turbo for it. any advice? thanks guys..
Our stock pump shoudl be sufficient I would just go with this.
http://www.intense-racing.com
INTENSE™ Oil Pressure Kit
Part OPK-671
Motor oil is the lifeblood of your 3800 engine, and any form of auto racing significantly increases the amount of work you're asking your oil to perform. The INTENSE™ Oil Pressure Kit allows you to increase WOT oil pressure in your 3800 Series II or Series III engine from approximately 50 to 55 psi to a race-oriented (and much safer) 80 to 85 psi. These numbers are based on using 20w50 motor oil and engine operating temperature of 180º F.
This is a wise mod for anyone who races his 3800 on a regular basis, and a MUST HAVE mod for anyone using the factory oil pump to support a centrifugal supercharger or turbocharger.
Each kit comes complete with a new oil pressure relief valve, oil pressure relief spring, a high precision, case-hardened, black oxide finished shim and new oil filter bracket gasket.
is that for a 3.8 though? i have a 3.4 and Im lookin at puttin a turbo on it...Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
yea that is for a 3.8, he probably thought you had that. Maybe someone else has something for ya, I will look around as well
meilings sells a pump for the 3.4
look over at FTPP.netBen<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
yes.. i konw melling sells one, but i'm curious as to whether its necessary or just additional parasitic drag. i was thinking it might help once i add a turbo.Phill<br /><br />95 camaro... need money for turbo project... <br />94 S10 Blazer - winter beater - infinity system to be installed soon<br /><br />\"The man who says it cant be done should not interrupt the man doing it...\"
