Heavy Duty 3800 Rebuild - FirebirdV6.com/CamaroV6.com Message Board
  • Heavy Duty 3800 Rebuild
    Well, it happened today. The engine died.
    The turbo wasn't even in yet. I guess I'm glad I didn't yet.
    So guys, here's my plan:
    While a V8 swap would make me salivate every time I turned the key, I don't quite think I want to buy someone else's shyt-kicked engine/trans combination, especially since I now have a tranny that can handle more torque than any V6 has any business putting out.
    So I want to build the 3800 SII. Where do you guys recommend I look around for internals? I'd like to do forged, since I'm going into debt ridiculously anyways.
    Any sites or reviews on a 3800 build up you guys can point me to?
    \'97 Camaro: GN Turbo w/intercooler, 3.42s w/ Auburn HD posi, Bulletproof 4L60E-HD, stage II shift kit, Vette servo, MSD Ign, K&N, Ported TB/MAF, 3\" FlowMaster, 160* thermo, HPTuners v1.6
    Well I was just the other day making a dream built motor for nitrous, you could change the cam and maybe a few other little things and it would work great with a turbo. Here is my list I made.
    Item Price Bought From:
    Spare Motor $300 camarov6.com (not needed, but you never know)
    HP Tuners $400 HP Tuners
    XP Hot Cam $300 ZZP
    Comp Cams 915, 105# Valve Springs $125 ZZP
    Comp Cams Hi-Tech Push Rods $96 ZZP
    Low Profile Valve Spring Retainers $37 ZZP
    SI Stainless Valves $0 supersixmotorsports.com
    Valve Seals $19 ZZP
    SSM Stage 3 PowerPack $1,600 supersixmotorsports.com
    P&P heads $0 supersixmotorsports.com
    P&P Intakes $0 supersixmotorsports.com
    Polish heat treat Crank $75 More Power Inc. (in GR)
    L32 Connecting Rods $259 3800performance.com
    Wiseco Forged Pistons $650 supersixmotorsports.com
    Balance/Blueprint Motor $125 More Power Inc. (in GR)
    Cam Install Kit $95 ZZP
    Timing Chain $36 ZZP
    ARP Connecting Rod Bolts $100 ZZP
    ARP Head Stud Kit $80 ZZP
    ARP Main Stud Kit $50 ZZP
    Clevite 77 Cam Bearings $15 ZZP
    Clevite 77 Main Bearing Set $50 ZZP
    Clevite 77 Rod Bearing Set $25 ZZP
    Intense Oil Pressure Kit $28 ZZP
    B&M Tranny Cooler $40 AutoZone
    Total $4,505
    http://www.bowtiev6.com/
