how hard would it be to switch out a 3.4 to a 3.8 in a 95 firebird? blown head gaskets and an auto tranny that looks like it is about to go to the big junkyard in the sky in about 10 to 15 thousand miles. was told it would be bout the same cost to replace the engine and i figured why not beef up by 40 horses in the proccess.
3.4 to a 3.8
Gonna take just as much work as putting in a V8. If you're gonna do a swap, don't waste money on another V6.Matt
1998 Mystic Teal Camaro M5
It's actually harder to put a 3.8 in than an LT1.<b><a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six©</b></a><br /><a href=\"http://www.sounddomain.com/id/95batmobile\" target=\"_blank\">My \'95 Bird</a><br />I am not afraid of storms, for I am learning how to sail my ship.
coming form someone that had a 3.4L and a 3.8L... I'd put an lt1 in.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
It is hard to do the v6 to bigger v6 swap.
You will need a wrecked 3.8 car to get all the parts form, that will be the main thing you will need.
It is a good idea to build a mean 3.4L\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
also, having done a 3.4~3.8 swap (third gen style) the engien harness & pcm are probably gonna be the biigest problems. Also getting the 3.8 with the mounts & brackets, as they are soooooooooo different from the 3.4.1978 Formula 461 in progress of being built :rock:
2013 Ram 1500 Big Horn
94 comero 3.4
I did the swap in my 94. You're biggest issue will be the fact that your 95 is not OBDII and all the 3.8's were(cept maybe the 2nd half of 95's). I ended up swapping in the entire chassis harness to make life a little easier. I ended up turbocharging mine, so it wasn't a big deal as far as power for me, but looking back I would've done an LT1. Not because of ease, just because I like v8 N/A power. It's really not that hard of a swap if you take your time and plan it out. If you have any questions drop me an IM at ataris1618. Its all still very fresh in the memory. I also did the auto to manual swap at the same time....
~Tom1994 Camaro: Firebird Interior, 3.4L to 3800 converted, OBD2 converted, A4 to M5 converted...In the turbo retirement home...<br /><br />1994 Mustang GT: 347 Forged Stroker, Port Matched Edelbrock Heads and Intakes, Tremec 3550 T-5, Spec Stage 2
Originally posted by Dan Oyer:
now then two questions. first how hard is it going to be to go to the 5.7. and second would all of you ignore me if i did not have a v6 anymore? :(
Search for the V8 swap...get the motor from a yard, ebay, etc.
I think you'd be better off
1)Rebuilding the 3.4 and making it stout (even if that means the 3.4 runs high 14's, but remember the 3.4 runs high 16's stock).
2)Just fixing the car to where it runs decent, and being happy with a 6
3)Junk it for an 8 already.-1999 Camaro Coupe 3800 Series II V6 A4 - SOLD<br />-1998 Pontiac Grand Prix GTP coupe
