So what all does it take? If I find a 97 3800 auto bird, and put the L67 in, what all will I need to make the swap sucessful?
thinking about putting my fieros L67 into a bird.
Its doable the problem you will run into i the supercharger fititng under the cowl... I say go for it, if I had a spare car, I'd do it.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
its not supercharged anymore, its turbo'd now. I built a custom intake for it.
http://www.fierox.com/turboengine9.jpg
Im thinking putting the intercooler up under the dash where the AC stuff would of been, and running the boost pipe straight out from the cowl into the throttle body.
All series II 3800 blocks are the same. Yeah my engine is turned sideways, but mounted to a 4L60e from a V6 car, itll bolt right up with no problems. The stock firebird wiring harness should snap right to it also, itll just take a custom computer program.
Any more ideas?<a href=\"http://www.fieroX.com\" target=\"_blank\">www.fieroX.com</a>
ahh you should be fine then...
just hook it up, gonna need hptuners...
Issues may be running exahsut through the K-member, to thte back of the car. May wanna consider getting an aftermarket k-member.-Eric<br /><a href=\"http://www.cardomain.com/id/mustangeater82\" target=\"_blank\">2000 NBM V6 Camaro 5-speed</a> T-top <i>converted</i><br /><b>14.467@95.45mph</b> <i>$0 in mods</i><br /><i>The member formerly known as MustangEater8251</i>
i could build my own K-member from scratch, not a problem. Thinking about running "dual" exhaust systems. Have one thats set up stock, sounds stock looks stock. Then have an electric cutout that dumps over by the passenger door or something.<a href=\"http://www.fieroX.com\" target=\"_blank\">www.fieroX.com</a>
on my L67 or on a stock L67?
Mine has:
diamond 8:1 forged pistons
L32 rods
balance shaft delete
balanced rotating assy
roll master double roller timing set
LS1 valve springs
comp cams lifters
smith bros pushrods
custom grind erson cam
ported heads
custom upper intake with LS1 throttle body
cometic head gaskets
custom stainless exhaust
Garrett T-66 turbo, .70 a/r turbine (but switching to .84) 21 psi of boost
Spearco 2-230 water/air intercooler
meziere electric water pump
and lots of other stuff that added to more than $6000<a href=\"http://www.fieroX.com\" target=\"_blank\">www.fieroX.com</a>
dyno'd 477 wheel hp and 515 wheel torque in my fiero. HP peaked at pretty much peaked by 5300 though, weve determined my turbine housing is too small and im losing power up high because of the restriction. Ive got a ported turbine about to go on, and a new cam will be in within a month, I think we can get 520 whp or so out of it.
dyno sheet
www.fieroX.com/dyno477.jpg
videos
www.fieroX.com/turbodyno1.wmv
www.fieroX.com/turbodyno2.wmv<a href=\"http://www.fieroX.com\" target=\"_blank\">www.fieroX.com</a>
whoops sorry, those are the old dyno videos from back when i was non intercooled. heres the new ones.
www.fieroX.com/dyno477_1.wmv
www.fieroX.com/dyno477_2.wmv
the first pass of the 2nd video was the highest pull. I have a 4000 stall, so it was losing alot of power through the converter. For that pass I locked the converter. On the next pass I tried to bump up the boost a little more and we had a mishap. (30 psi of boost). Thank god for 4 layer cometic gaskets. haha.<a href=\"http://www.fieroX.com\" target=\"_blank\">www.fieroX.com</a>
