Who all has the crane 2030 cam in they 3.4? - FirebirdV6.com/CamaroV6.com Message Board
  • Who all has the crane 2030 cam in they 3.4?
    I've heard people have luck and people have no luck, i got mine going in soon and im just needing some feedback.
    New:04 GMC Sierra 1500 RCLB 4x4 5.3 GU80 3.73\'s.<br />Truck pics<br />Mods<br />Go fast: Panel K&N filter and soon SS truck catback.<br />Appearance: Stull Billet grill,Weston Chrome step tubes,Rhino Chrome hitch step,ARE painted fiberglass cover,Silver star lighting.
    I got the crane 272 grind because it will work good with a turbo.
    That 2030 has some good valve over lap and should make a nasty idel.
    You will need to better you intake and exhaust to even get an idea of what that cam can do.
      he is looking for info on this particular cam due to the fact that it has no camshaft position sensor tab on it... he is hoping that it wont be needed as long as the crankshaft position sensor is functioning properly
      we are thinking that teh cam position sensor is only there so if the crank sensor goes out then the car can still find TDC and make its way home instead of leaving someone stranded... if this is true the the 2030 cam will work as long as the crank sensor is functioning
      -Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
        thanks lol..
          hey, not to sure but i think that is the cam in my car, the cam gives me a nice throaty idle and alot more power expecially top end
          1995 Camaro, Mods, Crane Camshaft, and Lifters, 160 Stat, Flowtech Dual 3.5 inch exhaust, gutted cat
            Crane designed the stock 3.4 cam. Compare the numbers between teh 2030 & 3.4 ;)
            2013 Ram 1500 Big Horn
            94 comero 3.4
              ????explain?
                12353919 - Camshaft Kit
                All models car and truck Chevrolet V6/60º (2.8L & 3.1L) for off highway use. Smooth idle, daily usage, off road, towing, economy, mild turbo-charged 8.0 - 9.5 to compression ratio, 2200 - 2600 cruising RPM. Basic RPM range 1500 - 4000, 6500 RPM attainable with proper valve springs and lifters. This camshaft kit is designed and manufactured by Crane Camshaft Co.r for GM Service Parts Division. The kit includes (1) camshaft and (12) tappets. The duration at .050 lift (intake/exhaust) is 204º/214º, while the value lift is .420"/.442". Lobe centerline is 112 (I don't think it has the cam shaft sensor tang)
                12363220 Camshaft
                This performance flat tappet hydraulic camshaft is used in the new 3.4-liter engine conversion package (P/N 12363230) and is also applicable to 2.8-liter and 3.1-liter engines. Designed to increase mid-range torque and horsepower, this camshaft is ideal for daily performance usage. The duration at .050" lift (intake/exhaust) is 204º/216º, while the valve lift is .427"/.454". The basic RPM range is 1500-4500, and the lobe separation is 107º.
                Technical Notes: Use with valve spring P/N 12363215 and retainer P/N 12363216
                12364059 Camshaft Kit
                Applicable to all 1980-94 Chevrolet 60º V6 (2.8-liter & 3.1-liter) engines, this performance-oriented camshaft kit is designed to significantly improve mid-range torque and horsepower without sacrificing idle quality. The basic RPM range is 1500-4500 with 6500 RPM attainable using proper valve springs. Cruise RPM is designed for 2200-2600 RPM, and a compression ratio of 8.0-9.5 to 1 is recommended. This kit is not legal for pollution-controlled vehicles. This camshaft kit is designed and manufactured by Crane Camshaft Co.® for GM Service Parts Division. The kit includes (1) camshaft and (12) tappets. The duration at .050 lift (intake/exhaust) is 204º/216º, while the value lift is .427"/.454". Lobe centerline is 112.
                Specs on 12363220 & 12364059 are the same.
                Link to GM perf parts pg: http://www.gmpartsdirect.com/perform...s/frameset.cfm
                94 comero 3.4
                  Not certain why you think they are the same when one has lobe spacing of 112 and the other is 107...
                  83 S-10 w/95 3.4 SFI, 4L60E
                    Im looking at getting a 2030 right now and am a little slow right now to understand this. Is the 2030 cam a good cam upgrade or should I leave mine stock? I want a few extra ponies.
                    So the question still stands.......
                    Does anyone have one?
                    ---Niño---<br /><i>95\' silver 5 spd</i>
                      dont get the 2030 cam if u have a 95 3.4 the camshaft sensor wont read cause theres no lobe
                      1995 Camaro 3.4 M5 - Project<br />1998 Camaro 3.8 A4 - Daily<br />Aim:V6OnSpeed<br /> <a href=\"http://www.cardomain.com/memberpage/576233/1\" target=\"_blank\">http://www.cardomain.com/memberpage/576233/1</a>
                        stil runs... just fine too..
                          Originally posted by GordSipko:
                          </font><blockquote>quote:</font><hr />Originally posted by 3.4 slow to go:
                          Not certain why you think they are the same when one has lobe spacing of 112 and the other is 107... </font>[/QUOTE]yup, they both have a diferent intake centerline too, the ht3.4 cam isn't made by crane(but is sligtly copied from it)
                            Ive got the 2030 crane cam in my 94 3.4L .The car runs fine but it runs slow as hell.Im not sure whats wrong with it. Ive had it checked 3 times and the guy that rebuilt my 3.4 says the car is fine.
                            The car should be running quick but instead its slower than ever. The car runs great but im not sure why its that slow. Maybe some tuning is needed? I dont really know. This is why I bought a GTP.
                            2002 Grand Prix GTP- FWI Intake , flowmaster 40\'s ,3.4 pulley , and Intense racing PCM.<br />94 3.4L camaro -Lots of mods!
                              Forgot them hydraulic cams. Go get a crane 250801 solid lifter cam and have some real fun!
                              And with the cam sensor, OBD 1 cars use it just to verify the crankshaft sensor. If the crank sensor went bad, the engine would still run using the cam sensor and it would throw a code. You can get away with using a cam without the camshaft position sensor lobe but you will be out of luck if the crank sensor takes a dump on you.
