<blockquote>quote:</font><hr>Originally posted by Ironman24:
If your EGR valve is sticking then it will throw hot air in the intake and cause a stumble under load, usually around 2-3K. I had this problem a long time ago, thought it was spark but found out there was a recall on the EGR units because of the sticking valve. Maybe 20% load is when the computer opens the EGR valve up. It's usually under cruise with load, never at WOT or high rpms.<hr></blockquote>
Lets say this is the problem, what kind of misfire readings would I be getting from OBD II? I've been watching these for each cylinder, but I can't make heads or tails of the readings. One cylinder shows around +150 all the time, while all the others show between 0 and -6. I don't have a clue what to look for.
