i was at the drags and could never seem to get my engine very cool. Im on a very very low budget and was wondering if I could just pull the thermostat out just for races. then just put it back in for regular driving. pros and cons????
gains????
also, would this be able become another free mod, besides the gasket.
96 Camaro 3.8 A4 Basemodel: 8 mm wires, Shift Kit, Hollowed <br />Cat(o2 sims), RKSport exhaust, IAT 5.6K resistor, Home Depot CAI<br />>>>15.375 @ 89.27<<<NEW BEST TIME <a href=\"http://www.cardomain.com/memberpage/552491\" target=\"_blank\">http://www.cardomain.com/memberpage/552491</a>
go to zzp and find the write-up on drilling holes in your thermo... not exactly what you wanted; but has been done before...
taking the thermo out would acheice what?
coolant isnt going to circulate without the engine running, unless you get an electric water pump........
- \"So you have something to look at when you\'re talking to \'em\" - <br /> <a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=296916\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=296916</a>
its going to heat up anyway, even if you are sitting cold at the start, by the time you get back to the line you'll be hot as hell.
i thought you meant for cooling purposes.... simple mistake.
prolly just like if you took off your serpentine belt to run engine not losing lil bit of power running those accessories. but something i wouldnt suggest because get way too hot
99\' W68 Firebird<br />SLP Ram air kit,Whisper Air Lid, k&n, 8mm Taylor Wires, Bridgestone Potenzas RE950, BMR Red LCAs, Pacesetter Headers and 3\"in catalytic converter with 2.75\" Flowmaster Cat-back<br /><br /> <a href=\"http://www.cardomain.com/memberpage/501008\" target=\"_blank\">http://www.cardomain.com/memberpage/501008</a>
There was a guy at camaroz28.com that would change out his thermo spring and fall.
He would do a 160 in spring to run a litle cooler and run a 180 in the winter for some heat.
But he got tired of that and got his 180 and drilled 2, 1/8'' holes and his car stayed cooler in the summer and warmer in the winter compaired changing the thermos.
He had a 3.8L too.
YOu could rig a line (at least 1/2'') from the pressure side of the cooling system to the non pressure side before the radiator and put a valve in and open it up at the races.
I know on the 3.4's there is a hole in the pressure side of the cooliing system it is only for the tb warmer. If the 3.8 has any thing like that, well there is your pressurized coolant.
It could be done once for kinda cheap and will get you what you want any time you want it.
You won't have to keep changing any thing.
