after putting my car back together from installing underdrive pulleys, it won't start. Both the battery and alternator are finr (were tested), and when i turn the key, i hear the hum of the ignition, but no tick, or nething from the starter, although the starter was fine previously. I used a crowbar to stabilize the flywheel, and am afraid that i jamed that up or seized it. PLease help asap!
Car won't start after Pulleys installed
if the starter turns, the flywheel turns, they go hand in hand. from what it sounds, you messed something up w/ the flywheel/starter gear assembley. try removing and reinstalling the starter (not too hard at all) and see if that fixes it. your gear may be off somehow, or the starter itself may be totally shot (could just be coincedence).
when you take the starter off, have a friend hold it TIGHT, and crank the car once and see if the starter output shaft spins at all. if it doesnt, its a bad starter, if it does, reinstall it and see if it cranks the engine. if still nothing, its the flywheel somehow, but i dont know how.
sounds like your starter just isnt getting power somehow tho, cause it doesnt even tick. do you have a multimeter to check it w/ the ign. on?
Originally posted by whiteThunder:
if its the flywheel, how much of a PITA is that to fix? also, if somehow i jamed it up (the wheel) too far, can i tap it down???
Did anybody bump into a starter connection with a tool while they were down there and blow a fuse maybe?\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
WTF did you replace? If you're a 3.8, then you only did the WP and Alt, which shouldn't mess up anything.
If you're a 3.4, then you maybe did the crank pulley as well. Not sure why everything wouldn't just line back up ... ?<b>97 Camaro 3.8L M5</b><br />Car for sale<a href=\"http://terpmotors.com\" target=\"_blank\">terpmotors.com</a> Terrapin Motorsports! UMCP
Also, so if i turned the flywheel counterclockwise by accident, instead of clockwise, does that matter?
Oh, and check this one obvious thing too, make sure the car is definitely in park all the way if it's an automatic.\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
