I'm asking in advance to please not move the topic since I've already tried it in the general tech forum without any responce and since I you people know more about these cars then most of the other people on this board I'm asking for your help since you have extensive knowledge of these cars. Please help a friend, I've always tried to help anybody in need of info and all I ask is for the same. Please help this whole thing is really pissing me off. Thanks in advance.
For the past week or so I have been having major problems starting my car. I will turn the ignition key and I'll hear it start to crank and then either the engine won't turn over or it does and then the rpm's jump to 2k and then dies quickly. Its weird because it doesn't do it all the time it is at random that it happens. Sometimes it will just start right up like normal then other times it takes 2-4 tries to get it to start. Sometimes I even have to push the accelerator slightly to have it start. It's starting to piss me off. Their doesn't seem to be any charging problem and the battery has a little eye hole that says that its charged. Its kind of a random occurance thing. I don't want to hold the ingnition key to long or else I run the risk of burning out the starter.
I tried some seafoam cleaner and it didn't help at all. I've also tried to reset the computer twice and it helped minimally. Their is also a rough idle while I stop at a red light or have my foot on the brakes. Any other time while the car is running it acts fine and their isn't any problem with accleration or stoping or anything electrical. The only underdrive pulley I'm running is the crank one and I've had it on their for a long time.
Any ideas or suggestions would be greatly appreciated. I even clean out the intake elbow just in case something was blocking it and check the vacuum lines. Their are no leaks and I even cleaned the belt. Any ideas. Thanks for any help in advance.
Also thier is some smoke sometimes when the engine finally starts. It is at random though.
Could it be spark plugs, coils, wires, alternator, battery, or the O2 sensors. I've replaced most of this stuff in the past year or two so none of it should be bad.
I need help fast. The hard starting is at random and thier doesn't seem to be any pattern to it. Please I'm taking the car in on thursday or friday to get checked out by the dealership. I would like to have some idea of what could possibly be wrong. Also when it finally starts and I can drive after cranking it several times it seems to have a hesitation at low acceleration/start of acceleration without having to floor the accelerator.
Once again thanks in advance for any help. I appreciate any and all comments, suggestions, ideas, etc. Thanks.
