Mysterious Coolant Leak... - FirebirdV6.com/CamaroV6.com Message Board
  • Mysterious Coolant Leak...
    About every 4 months or so (this has happened twice), my car's (1998 3.8 A4 Camaro) temperature gauge goes crazy, up and down like it's overheating. I check the coolant, which gets very low, fill it up, and it's fine for another 4 months. Well, week ago this happened for the second time and I decided to bring it to a shop for checks because my SES light is on now too. It's throwing two codes, both for P0147 (HO2S Heater Circuit Bank 1 Sensor 3 - Post Converter). Well we figured it might be a head gasket, so after getting it tested with a pretty insufficient test, they said yes.
    Well I brought it somewhere else and after over 4 hours of testing, they cannot find any leaks anywhere... not the radiator, gaskets... anywhere. Now I'm ****ting bricks because I don't know what's going on. You guys have any suggestions?
    ... I have had my 3.4 for about 8 months now with the same problem.. it gradually got worse (filling water once a week) then finnaly today i found a large crack in the radiator.... dealer even pressure tested system and found nothing in december and again in march... now I need a radiator and the closet one is in Los Angeles...any one have one for sale? that could ship it quick possibly.
      I'd put money it's the waterpump man. They aren't too expensive and are easy to change.
      -Brad
      2000 V-Star Custom 1100
      :rock:
        sounds like the thermostat is just sticking 8$ fix
        the coolant isnt leaking really, its boiling off thru the raidiator cap
        -Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
          that happened to me when my waterpump and my thermo was a screwed up. got those two things fixed and no problems since.
          1994 Camaro 3.4 L V6 <br />2.5\" Flowmaster 80 Series American Thunder Exhaust<br />SLP Cold Air Intake<br />Sony Head Unit<br />Pioneer Midranges<br />2 10\" Sony XPlod 1100 W Subs<br />Power Acoustiks 980 W Amp<br /> <a href=\"http://www.cardomain.com/id/heartbeat_of_94\" target=\"_blank\">http://www.cardomain.com/id/heartbeat_of_94</a>
            Also, you may have a front cover leak. (covers timing chain, behind the waterpump). Mine would only leak when the engine was warm, so it never left any puddles.
            UAH FSAE<br />Chief Engineer<br /> <a href=\"http://chargermotorsports.com\" target=\"_blank\">http://chargermotorsports.com</a> <br /> <a href=\"http://members.cardomain.com/camaronat\" target=\"_blank\">http://members.cardomain.com/camaronat</a>
              6 days ago
