Has anyone ever built a screamer? - FirebirdV6.com/CamaroV6.com Message Board
  • Has anyone ever built a screamer?
    When I say screamer, I mean a high RPM engine. 7000+.
    If not why hasn't anyone?
    Turbocharged and intercooled.<br />17psi(oops), stock fuel pump, no FMU<br /> <a href=\"http://www.cardomain.com/id/phoenix64\" target=\"_blank\">http://www.cardomain.com/id/phoenix64</a> <br />Video: <a href=\"ftp://ftp.pfabrication.com\" target=\"_blank\">ftp://ftp.pfabrication.com</a> Assorted car ****: TurboCamaroFull.
    The factory gm computer is limited to 7200, so you'd need to piggy-back the comp or use a stand alone, but it could be done, some of those gtp guys come pretty close to 7k.
      i know someone on here is really pushing it i think its viper.
        most people dont do it because if you rev the motor that high very much you will collapse a hydraulic lifter... and not many people are that dedicated to switch over to a solid roller setup due to matinance issues
        -Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
          factor pcm only goes to 6500 but you can rev higher (as far as fuel and timing), i have rev to 6800 only to see what it was like [img]smile.gif[/img] (and i liked it alot :D ) i usaly dont go over 6400 just to be safe
          intense has one of there cars going to 8000 RPM
          www.turbov6camaro.com
          1997 3800 Series II Camaro
            with some of the stuff intense has been making lately that motor might not last very long then
            1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
              I have built a 14,000 RPM motor.
              a '01 GSXR600.. [img]smile.gif[/img]
              Gotta have the short stroke.
              Also building a 9000+ rpm 302 chevy.
              yes, chevy.
              1997 Dodge Viper GTS
                u know if that was a ford 302 it wouldnt hold 9000rpm ;)
                  Our computer only goes to 6400, however above that, the spark and fuel tables use the same values. My plan for my spare 3800 is to shift at 7500 with a redline somewhere around 8k.
                  2002 Pewter V6 Camaro M5 <br /><br />Quickest stock-motor N/A V6 4th Gen F-body.<br />2nd Quickest N/A V6 4th Gen F-body overall.<br />mods: Gear, weight reduction, tuning <br /><br />Fear the Gear. 13.585 @ 100.05 1.827 60\'<br /><br /><br /><a href=\"http://www.NJFBOA.org\" target=\"_blank\">www.NJFBOA.org</a>
                    Does anyone know what kind of quarter mile times would be gained by this extended power band?
                    2000 Mystic Teal Firebird<br />Full 3\" exhaust, FRA, Aluminum Driveshaft
                      that depends on how much power you are making at thowe RPM
                        I knew that [img]tongue.gif[/img]
                        What I mean is, does anyone have any kind of numbers that show the differences in individual cars with the rev limiter at different RPMs to give us a general idea what this particular goal could do for our own cars?
                          The point is anyone who would rev their motor that high would have a rebuilt motor to handle it. Nobody(i hope) is just raising their rev limiter for the hell of it without making other adjustments. HP peaks at 5200 and torque peaks at 4000.
                            My redline is at 7,000 rpms if that counts [img]tongue.gif[/img]
                            <a href=\"http://community.webshots.com/user/maniacls1\" target=\"_blank\"><b>2001 Firehawk #155 of 504 -M6</b></a><br />437 RWHP / 404 RWTQ -Dynojet (heads/cam)<br />12.34 @114 mph 1.7 60\' (bolt-ons only)<br />12.47 @116 mph 2.0 60\' (street tires, heads/cam)
                              so was mine, and no it doesnt [img]tongue.gif[/img]
                              00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
