wickedsix9838, do u know what compression ur runnin with them heads, i was fixin to get my heads done and figured i wouldn't be able to go more than 10:1 since our heads are cast iron and might lead to more detonation problems. If you have an idea that would really help, i'm fixin to get on the ball with this motor work.
hey wickedsix9838
My motor is 9.5-1. The heads were milled .015" and it raised the comp ratio .1. With a little more milling we could get the motor closer to 10-1 but I probably wouldn't mill them over .030".<b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
