Yet another v8 swap. Here are the details I have a 93 v6 camaro auto tranny no mods no speed. I also have an lt1 long block no motor plate witch I think I will need innless old school excesory brackets can be used. I have been reading up on the swaps and yes I used the search but every one says you have to go to a v8 k-member but y cant you use the v6 one and make new holes for the v8 motor mounts. And o yeah im looking at going with the carbed intake from summit just because I can get cheep and good carb and distributor I know a distrubither will go in to the lt1 because it still has the gear on the back of the cam for one but im not sure if anything has to be dun or changed like distributor gear or something. I also heard you cant use the v6 radiator and fan. Why not do the hoses not fit that’s not that big of a deal and the fans I don’t see why they wont work not enough cfm’s compared to the v8 ones I guess.
1. Will a v6 k-member work with new holes for the v8 I think the v8 holes are 2 inches or so further back than the v6
2. Why wont the v6 radiator work and fan
3. What if any distributor modifications will have to be dun (and for those who don’t know yes a distributor will fit under the fire wall it may have to be cut but it will fit)
4. Excesory brackets I would like to use all the excesoried it gets kinda hot in south NJ during summer so Ac is very nice.
5. If you disconnect the engine pcm will the brakes work correctly and will the abs work not such a big deal but nice to know
6. im not sure but I think the v6 fuel lines and pump will work with FPR because 60lbs or so the v6 fuel pump puts out is to much but it might need a fuel pump booster for the volume
7. and a tranny k-member im looking at a th350 tranny so will my v6 tranny k-member work or will a stock th350 tranny mount fit
and for the people that can only say sell the car and by a v8 car pleas do not post iv ben researching this for over a year and this is somthing i would like to do its diffrent alot of power and you have to love a carb
