building twin turbo car should i or not - FirebirdV6.com/CamaroV6.com Message Board
  • building twin turbo car should i or not
    i have plans to build my twin turbo car but i just got my hopes thrown in the garbage. i just went with my neighbor to his friends house and his friend knows alot for almost every car and he told me this:
    1 my suspension needs to be rebuilt and possibly converted to a corvett suspension
    2 my transmission suck at 400 hp
    3 my t-tops are going to break any way at 400+
    4 my timing chain is old school that i should convert it to belt.
    5 my supension sucks!!!
    should i still do my project or listen to this guy
    and not do twin turbo. ( i want to do twin turbo bad because its rare to have a twin turbo setup in our cars!!!)
    Is it a V8? NO! It's a v6 foo
    Mi Caro...
    http://viewmorepics.myspace.com/inde...3-dfc38675ce8b
    You do need to build up your suspension but the F-body suspension can be built up better for drag racing than the corvette suspension. The transmission will need to be built up. I dont know where he got the deal about the T-tops breaking, no way. There is not a belt drive system for the 3.8. They do make a double roller timing chain though. Do your project. He doesnt know as much as he thinks.
    <b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
      1. Yes, it sucks for anything more than 200hp/225tq. You wouldn't want a tire burner would ya? You would want to upgrade the suspension even on an LS1 or LT1 if it were putting down 400+ hp. There aren't too many stock v8 rearends that can even handle 400+ hp/tq for a prolonged period of time.
      2. Yes, our transmissions weren't meant to last very long on 400+ hp/tq. But if you're putting all that money into the engine you better find a way to get the power to the ground efficently or else it's just a show piece.
      3. I wouldn't think so. The car may twist and flex but it shouldn't break the t-tops. If I'm not mistaken, there are quite a few t-topped f-bodies rolling around with 400+ hp.
      4. If you're building a race car then do it right. Intense Racing sells a nice timing chain, although they have been under some pressure lately.
      5. Not for what it was intended for.
      If you want to build a race car then do it right. Once you start cutting corners you will regret it later on.
      1998 A4 Pontiac Firebird
        Thanks. And i am going to build this car!!
        nomatter what some fools say. thanks
        Mi Caro...
          Let me put it this way. In a high powered engine, Would you rather have a rubber belt controlling your engine or steel chain. [img]smile.gif[/img]
          92 S10 3800 A4(96)<br />1/4: 14.374 @ 92.25 w/ 1.976 60\'<br />Turbo and 12\'s Coming Soon!
            Originally posted by RedFrk13:
            </font><blockquote>quote:</font><hr />Originally posted by Firebirdedgar:
            Let me put it this way. In a high powered engine, Would you rather have a rubber belt controlling your engine or steel chain. [img]smile.gif[/img] </font>[/QUOTE]Actually, the belt driven systems are better than the timing chains BUT like I said, there isnt one offered so its a no go.
              id rather have timing chain (dual)
              Mi Caro...
                WHY in the HEck would a piece of rubber be better than a roller timing chain. WHoever thinks a piece of rubber is goona hold better than a chain is insane!!
                  I have herd that the belts keep crank vibrations out of the valve train and they take less torque to turn over compaired a regular chain.
                  But then you can let a chain go for over 150,000 miles they just kind of ware out, a belt will let go about 100,000 and you engine will be junk.
                  That's why gears rule [img]graemlins/rock.gif[/img] [img]graemlins/banana.gif[/img] .
                    AMEN!!!
