How would 24lb injectors and a high volume pump affect a NA 3.4L? I'm in the process of rebuilding my 3.4 and I'm going to upgrade to 24lb injectors a high volume pump for the turbo later on. I won't be getting the turbo until fall/winter (or second FFF GP) but I would like to atleast put the new injectors in while I have the engine apart. Will the new pump cause me to run rich?? If so I also purchased an adjustable fuel pressure regulator to have better control of A/F. Question is though should I install the new injectors and wait on the pump, or install both at the same time??
High Volume Pump & 24LB injectors for NA?
Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....Tags: None
24 is probably too big for NA application.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
what if i turn the fuel pressure down? how would that affect a/f?Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
With your mods it looks like you don't need eather one.
Those injectors will only hurt you.
For now it would be a waste of you time and money.
If you want more fuel get an ajustable fuel pressure reg. End result is the same as biger injectors but more use full.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
I'm in the process of rebuilding my engine so my list of mods isn't up to date. Anyway I've decided to go with 19lb injectors for now and then 24lb when I get the turbo.Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
I'm in the process of rebuilding my engine so my list of mods isn't up to date. Anyway I've decided to go with 19lb injectors for now and then 24lb when I get the turbo.99 camaro... WingsWest body kit, Billet grill, EBC Green Stuff break pads, tint\'s all the way around, magnaflow exhaust, ram air, Rebuilt trans, 3300 stall, and RS 3 alarm. FFF kit! <a href=\"http://www.cardomain.com/memberpage/452573\" target=\"_blank\">http://www.cardomain.com/memberpage/452573</a>
ebay=cheap injectors that will do fine for a couple of monthsBen<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
