basically can i build the whole thing on the stand, and then put it in. i have the radiator and just about everything out of the car now. i though it might be hard getting the tranny bolts on. your thoughts please?
Can the entire 3.4 Engine be built outside the car and then put it
yea. just put the tranny on after you get it in the car. take it in / out thru the hood. ive done it. doesnt take that long.
hybrid - \'\'hI-br&d - The offspring of a cross between species.
Co-Founder West Coast F-Bodies
West Coast F-Bodies Car Club - WCFB Message Board
If there is a better way please step in.\'85 Z28, T-tops new LG4 and TH700<br />\'85 3.4L 5-speed<br />mods: <a href=\"http://www.cardomain.com/id/oil_pan_4\" target=\"_blank\">http://www.cardomain.com/id/oil_pan_4</a> the nitrous exhaust O2 safety, pg 3. <br />Areo space materal engineer wantabe
i plan on just bolting everything together on the k member and then just roll everything underneath the car. I plan on putting my motor in the next couple of weeks so I'll have picutres when the time comesBen<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
i went from under the car when i did my swap. i even pulled hte old motor the same way.
its the easiest way and the most used way on these cars theyd ont give u much room to pull form up top.<a href=\"http://www.geocities.com/hemigtx001\" target=\"_blank\">http://www.geocities.com/hemigtx001</a> <br /> <a href=\"http://www.geocities.com/hemigtx001/Firebird_Index.html\" target=\"_blank\">http://www.geocities.com/hemigtx001/Firebird_Index.html</a> <br />1993 3.4L firebird<br />mods-flowmaster 80 series, removed cat. K&N FIPK. custom ram air ducts to filter.<br />Completed Engine Swap.
I put the tranny on and put it all back in through the top. The headers were the only thing that I waited on bolting on until after it was back in the car.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
well yea, you dont have to pull the tranny out, just gotta make sure its off the motor and supported by something in the meantime (there will be nothing to support the front of it)
other than that, should be no prob to leave it in there while you fix the engine.
i just got a new motor and i was wondering if it is posible to go thru the hood, cause i dont have a way to lift the car. If so is there details on how to do it?95 \"Deep Metallic Purple\" camaro<br />160 hp <br />1/4 mile in the 17\'s at 86 mph<p><a href=\"http://community.webshots.com/album/91867924TYiSkT?515\" target=\"_blank\">http://community.webshots.com/album/91867924TYiSkT?515</a>
UM how can u go through the hood if uc ant lift the car how u gunna lift the engine. i used a engine hoist to lift my car it worked jsut fine. just jack the rear end up. about 1 ft off the ground hook the hoist up to the radiator support. jack it up. about 3 ft and u can get it right under the car.<a href=\"http://www.geocities.com/hemigtx001\" target=\"_blank\">http://www.geocities.com/hemigtx001</a> <br /> <a href=\"http://www.geocities.com/hemigtx001/Firebird_Index.html\" target=\"_blank\">http://www.geocities.com/hemigtx001/Firebird_Index.html</a> <br />1993 3.4L firebird<br />mods-flowmaster 80 series, removed cat. K&N FIPK. custom ram air ducts to filter.<br />Completed Engine Swap.
i have and engine hoist, i just dont want to use it to lift the car. Ive already started taking the radiatior,and a/c condencer. the wires are alost done. it looks as if their is enough room to get it out so far.95 \"Deep Metallic Purple\" camaro<br />160 hp <br />1/4 mile in the 17\'s at 86 mph<p><a href=\"http://community.webshots.com/album/91867924TYiSkT?515\" target=\"_blank\">http://community.webshots.com/album/91867924TYiSkT?515</a>
i took the whole tranny and motor out at the same time and i plan on putting it all back in the same way. the only thing i had to do was take the upper intake off for the oil pan to fit over the crossmember.95 \"Deep Metallic Purple\" camaro<br />160 hp <br />1/4 mile in the 17\'s at 86 mph<p><a href=\"http://community.webshots.com/album/91867924TYiSkT?515\" target=\"_blank\">http://community.webshots.com/album/91867924TYiSkT?515</a>
i took my engine out thru the hood. put it back in that way too after i put the aluminum heads on it and rebuilt it.
Not sure how different a 3.4 would be, but i pulled my ls1 and transmission out through the top. i dont see how the 3.4 would be any harder (i would think easier).
I did have to pull my heads/intake manifold though. but i left my radiator in.1996 CamaroRS <br />15.5 @ 86<br />Sold<br /><br />2000 Z28 Convertible 3700lbs<br />Lid, Cutout, yank 3600 Stall, built trans, snall cam, NX Wet kit.<br />11.3 @ 118<br />Best 60\' is 1.58<br />497 RWHP 475 RWTQ
Things are a lot easier if you remove the engine and tranny at the same time. I don't know about lifting the car by the radiator support...doesn't sound like a great idea to me. Just unbolt the mounts and remove from the top. Most likely, you will have to remove everything down to the heads to get clearance to remove it from the top. You might even have to remove the heads. Not a tough job though.- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
