Whats up guys im getting my bottom end redon quite a bit here is my list
Clevite 77 Main, rod, and cam Bearings
Hastings piston ring kit
balance the complete motor include
rods,crank,pistons,harmonic balancer, and flywheel
Polish Crankshaft
line bore rods
removing balance shaft
Ok i only have one question and yes i have searched and found a couple of results but nothing definate. What do i plug the oil feed hole with or how for the balance shaft? anyways im pretty sure i will be able to turn some pretty sick rpms with this setup after i dop the top end too.
Polish Crankshaft
line bore rods
