anyone w/ aftermarket cam look inside - FirebirdV6.com/CamaroV6.com Message Board
  • anyone w/ aftermarket cam look inside
    I recently completed my engine build up and swapin my 98 camaro. I had my heads and intake ported and matched, heads were milled .020, comp cam 206-212 ,512-520 final w IC of 108 and LS of 112,918 comp spring w/ titanium retainers. I also installed 30lbs accel injectors.I had my PCM tuned by Dave Buckshaw for all of this.
    Now I have a problem though whenever I try to start my car sometimes it wont start unless I give it gas and when it does fire up, it idles up and down drastically for a sec or too. I had it at the dealer for an alternator replacement and they said they think my Idle air control valve might be bad anyone have any onther suggestions?
    Msd wires,Summit coils,Cuctom CIA&longtubes 2.5inch w/side exit,Cam,Heads & Intake,30# injectors,reprogrammed computer,3400 edge Converter, 3.73\'s&LSD,Edlebrock torque arm, SLP LCA\'s,Jegs panhard bar,16 inch nittos Best ET 14.374 @94 <br />Best 60\' 1.91
    Could be MAF related but it's most likely the large injectors.
      if it is the injectors, what could help?
        only thing you can do is go to smaller injectors or get the PCM programmed.
          With just a cam, I doubt you need larger injectors. Try running that cam with the stock ones.
          2002 5-spd NBM Camaro
          Details: www.1lev6.com
            If you don't want to go through swapping the injectors and getting the comp reprogrammed again, possibly try a maft+ and lean out the base setting a little?
            I'd try autotapping it first and see what is actually going on!
              <blockquote>quote:</font><hr>Originally posted by Nachius:
              <hr></blockquote>
              I'm with him.. before you go swapping parts out try and find out what's up..
              -Brad
              2000 V-Star Custom 1100
              :rock:
                Thanks for info,I did have my pcm tuned for the injectors, but since I dont have an autotap, I'm going to have the car put on a diagnostic machine so that I can see what the readings are. Would anyone suggest the mini afc for the tuning this out if it needs it?
                  The miniAFC works really well, and its inexpensive, if your only issue is fuel.
                    well i hear dave is one of the best programmers, so if thats true then it shouldnt be the injectors especially if he tuned for them. im running 26 lb ls1 injectors If dave is as good as what people tell me then i shouldnt ave a problem with the injectors either.
                    Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
                      On a cold start the computer isn't using the O2's just yet so it has to use the calibrations inside of the PCM to determine how much fuel to give it.. If they are not accurate it will start rough and kind of search for idle.. I've been there, ... and done that.
                      Put in a stock PCM with stock injectors and I bet it goes away... (that is if your MAF setup is still stock'ish).
