i got a 96 bird and i know i need a 97 pcm to get the tuning done. can it be reprogrammed for future upgrades or does it all need to be done at once. also when would it turn on the fans? what all would be involved with switching over to a 97 pcm? any help would be greatly appreciated. thanks.
HEY MATT I GOT A PCM QUESTION
It is a direct bolt-on replacement, no wiring changes needed. We can have the flash done here for $75 or you can have it all done by your GM dealership. Once it's flashed with the '97 operating system, we can always do updates and such with no problems.<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
So you can flash the 96 computer to 97 or are you talking about flashing the 97 computer?
I was wanting to talk to you about this exact same thing cause I have a 96 computer with the 96 3.8L and I want tuning done too.
(oh yeah, answered one of my questions: is it a direct bolt on)2005 Ford Focus ZX3 SE D20 M5 - Modified ;) <a href=\"http://www.knightenmotorsports.com\" target=\"_blank\">http://www.knightenmotorsports.com</a> <br />[ U R L = h t t p : / / w w w . g e o c i t i e s . c o m / h e a r t l a n d _ h e a t _ v 6 ] Heartland Heat V6 [ / U R L ]
You CANNOT flash the '96 to become a '97.
You have to get a '97 PCM and have it flashed to match the same specs as your car. Such as transmission, gears, etc...Polo Metallic Green \'96 Camaro w/Y87 Performance Package<br /><a href=\"http://www.cardomain.com/id/greenmaro24\" target=\"_blank\">Corey\'s Camaro</a>
Ah, now i getcha. I'll be on the lookout for a 97 computer.2005 Ford Focus ZX3 SE D20 M5 - Modified ;) <a href=\"http://www.knightenmotorsports.com\" target=\"_blank\">http://www.knightenmotorsports.com</a> <br />[ U R L = h t t p : / / w w w . g e o c i t i e s . c o m / h e a r t l a n d _ h e a t _ v 6 ] Heartland Heat V6 [ / U R L ]
You have to get a '97 PCM and have it flashed to match the same specs as your car. Such as transmission, gears, etc...<a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">www.fullthrottlev6.com</a> THE SOURCE!
