Yet another neophyte shopping for a cam - FirebirdV6.com/CamaroV6.com Message Board
  • Yet another neophyte shopping for a cam
    My camaro is the only car I have, and I won't be able to afford a second car for a while. I have to drive it to work and school everyday, in extreme hot and cold weather. The engine has 58k miles on it, and it will probably get 110k before I get a better car.
    I probably shouldn't get a big cam at all since my car needs to be reliable, but I can't ever leave anything alone.
    Will this grind from ZZPerf. give me years of reliable, fast service:
    206°/216° at .050"
    Intake Lift .315" (.504" lift at 1.6:1 rocker ratio)
    Exhaust Lift .315" (.504" lift at 1.6:1 rocker ratio)
    115 Lobe Separation
    does anyone have one of these? do they like it? [img]graemlins/dunce.gif[/img]
    1999 red camaro v6 M5: with a turbo<br />13.52@107.99<br />No, seriously: Who Farted? <br /><a href=\"http://www.cardomain.com/memberpage/600086\" target=\"_blank\">http://www.cardomain.com/memberpage/600086</a>
    That is the VS cam and while it will work it is TERRIBLE for n/a use. The only reason I know this is my buddy Mike Malloy owned one and I actually rode in the car with it. His n/a times weren't really any better than stock, actually.
    If you need a good cam, thats mild and works well, I can't help but recommend the 200/206 grind that comp themselves make. Its well made, good ramp rate, not too high a lift, and has good gains with the 112LS. I recommend ordering it with a 113 IC though, and not 108 like it is stock. The 108 will make it more powerful in the low end, but with such a small duration it doesn't harm anything to give it more high-end and sacrifice a little [img]smile.gif[/img]
    I know we all want the best cam for our cars, but you gotta figure out what you can live with. I think the LAST thing you should do is a cam, as it will change the entire demeanor of your car. If its a daily driver, wait until you can get something which you can drive just in case the cam install goes sour. Don't put yourself in a hurt locker when everything is still working fine, try to be prepared for anything.
    Make sure you're ready for a cam by having everything else you want done and straightened out... exhaust, intake, headers, thermo, radiator, suspension, appearance, anything [img]smile.gif[/img]
    Just some advice. I know its more than you asked for, but I hope it helps.
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      I forgot to mention I have a manual trans. I think that makes a big difference in cam selection.
      If I did buy this cam that dominic recomends, can anyone guess which of my valvetrain parts would fail down the road? I used to drive a monte carlo with a 350 and broken valve springs, it ran ok as long as i didn't race it.
        Here is a whole thread on the cam Dominic is recomending.
        http://www.camarov6.com/cgi-bin/ulti...&f=16&t=001596
        Hope that helps.
        Thanks, <br />JAM<p>02 Firebird GT
          comp's grind will work well for you or look at intense's grind. intense flow tested 20 different sets of heads to come up with a cam that would maximize power while still being perfectly streetable and work with the stock computer.
          i was swimming in the carribean. animals were hiding behind the rocks except for the little fish, but they told me the squid\'s trying to talk to me. oink, oink. where is my mind?
            Seppo is using the GT cam from zzperformance and dropped a second. He's now in the 13s N/A. [img]graemlins/thumbsup.gif[/img]
            <b>99 Camaro Z28 A4</b><br />R.I.P. 00 Firebird 3.8<br />14.89 @ 90, 2.03 60\'
              I went to Seppos website. He doesn't have many mods beside the cam. I would like to talk to him and find out if he daily drives his GT cam camaro. If so, his cam is the shiznit and I will have to get one.
              Jam- thanks for recalling that thread. This GT cam fits in the profile outlined in that discussion, but it is a little on the small side. I think it would be better on the small side though since I don't want to reprogram my computer.
              [ June 27, 2003: Message edited by: malice10985 ]</p>
