ok real quick...I searched forever it seems like but I need some help. i am about to order all the parts i need for the head cam install. This i what i have already: complete P&P heads and intake manifold, hydraulic roller lifters, hardened pushrods and head gaskets. I know I need injectors (24#), plugs and wires, I just need to know what else I need. gaskets? bolts? timing chain? anything fuel? thanx for ur help
have most part but know i am missing something for my head/cam install
SLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.Tags: None
assembly lube.
some bolts are one time use...such as the stock rocker arm bolts. you want reusable bolts if you can afford em.
Valve Springs?
HPTuners to tune the cam.
valve cover gasket, TB gasket, new PCV valve (save the O ring from stock PCV.
Valve Spring Compressor (unless your heads come with springs already...this is suggested...pick the springs to match the new cam and have the head people include em.
'break free' penetrating oil for exhaust bolts.
white grease pencil for numbering the spark plug wires.
A big socket and breaker bar for the harmonic ballancer.
lots and lots of baggies...a note pad...make any pertinent notes regarding placement of 'bolts' and place them in their respective baggies. don't just pile up all the different bolts and stuff. keep them seperate. A digital camera is great as well.
Don't rush.
ive already got the springs installed on the heads so that is no worry. so that is basically it? get all new bolts...it looks like the head gaskets that i got with the heads are used. would it hurt to ue them or should i get new ones? everything fuelwise is ok? no regulator is needed? and most importantly, what about a timing chain?? otherwise im set and thanx again for the helpSLP CAI, RK Sport headers, P&Ped heads and intake, GT2 cam, Upgraded valvetrain, Z28 rear axle with 4.10s Tx Spd tune, Z06 rims, 2.5\" exhaust to flowmaster, 160* thermo, B&M ripper, upgraded ignition, rockford fosgate 12\" with sony xplode amp and HU.
get new head gaskets or return them and ask for new ones, make sure you clean the surfaces before allowing the gaskets to seat on them, also for a timing chain just get a new one from cloyes, i got a whole chain and sprocket set from cloyes for 50$3\" Eldebrock catback exhaust<br />rksport powerdyne<br />pacesetter headers<br />VS cam,compcams pushrods,ls1 valves,5 angle valve job,p&p,<br />and total seal piston rings<br /> <a href=\"http://www.cardomain.com/ride/804031\" target=\"_blank\">http://www.cardomain.com/ride/804031</a>
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.4 hours ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...2 days ago
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....1 week ago
