Mild Cam in 3.4 - FirebirdV6.com/CamaroV6.com Message Board
Mild Cam in 3.4
  • Mild Cam in 3.4
    CRN-254112 is the part number from Summit.According to the specs of it,It seems to be a mild cam for the 2.8,3.1 and 3.4 motors.It says stock computer compatible.Since this is not a radical cam or anything is there anything else need to go along with this cam.Can I just pop this in and go or is there more involved?Is it also smog legal with a full exhaust and CAI?
    Specs of it:
    198 Intake lift
    204 Exhaust lift
    Intake and Exhaust duration:258 and 264
    401/423
    RPM Range:1,000-4,000 RPM
    you might gain 4 HP from adding that cam
    it would deffinetly work with stock tuning, lol it has 3* more duration than a stock cam and about a tenth of an inch more lift
    i doubt you would even feel a difference after adding that cam
    -Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
      Is it compatible with smog issues? Will it work balanced with a CAI and full exhaust?
        i dont see how it would cause any trouble with smog... its just a hair more agressive than stock.
        "will it work balanced with CAI and full exhaust?" ... explain, that makes no sense to me
          I mean driveability problems,like crappy idle etc....Since its not very aggressive,Can I just pop it in and go? or are there tons of other parts involved? It comes with new lifters also.
            go for a more aggressive cam....after all the work it takes to do a cam swap u will really be disappointed w/ the results from those specs
            1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
              How about this cam,i think its the next step up
              Basic Operating RPM Range: 1,500-4,500 RPM
              Intake Duration 050 inch Lift: 204
              Exhaust Duration 050 inch Lift: 214
              Duration at 050 inch Lift: 204 int./214 exh.
              Advertised Intake Duration: 264
              Advertised Exhaust Duration: 274
              Advertised Duration: 264 int./274 exh.
              Intake Valve Lift with Factory Rocker Arm Ratio: 0.423
              Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.423
              Valve Lift with Factory Rocker Arm Ratio: 0.423 int./0.423 exh. lift
                that would be a pretty good choice for a mild cam, i put a comp cam 206/212, which is pretty similar to that crane cam, in my 3.4 and its computer friendly and gave me about 10-15 hp. i wish i would have went bigger but its too late now.
                95 3.4 m5- comp 206/212, 1.6 roller rockers, pacesetter headers, magnaflow cat, dynomax 18\" bullet muffler, ss muffler and tips, msd 8.5 wires, 32mm sway, umi sfc,
