Hot Cam cause leaking oil? - FirebirdV6.com/CamaroV6.com Message Board
  • Hot Cam cause leaking oil?
    will the ZZPerformance Hot Cam cause my car to leak oil?
    1996 Camaro 3.8 M5.
    I read that it might so whats up?
    I know I need new springs and valve retainers or w/e..
    [ June 20, 2005, 06:51 PM: Message edited by: Justin B. ]
    If everything doesnt get sealed/tightened up it might leak oil.
      so other than that no problems right?
      any ways to make sure I get it sealed up right?
        If its done right nothing should leak oil.
          a torque wrench ;)
          1994 white Firebird M5<br />Flowmasters, CAI, 3.73s, LSD, coated pacesetters, eibach pro-kit, bilsteins, hurst shifter, JVC stereo, 18\" C5 vette wheels, Kuhmo Ecsta ASX rubber<br /><br /> <a href=\"http://www.cardomain.com/memberpage/744299\" target=\"_blank\">http://www.cardomain.com/memberpage/744299</a> <br /><br />Coming Soon: Turbo!
            I instaled mine and ran it for about 6 months and never leaked a drop. Do the job right, and it will not leak.
            2001 Firebird 3.8L V6 M5,<br />It once had....<br />NX Nitrous Wet Kit, ZZP X-P Hot Cam, <br />3.42 LSD, Pacesetter Headers, <br />36# Injectors, HP Tuners<br />322 RWHP, 379 RWTQ<br />13.596 @ 102.56 w/100 shot
              You're probably referring to burning oil caused by crushing the valve seals with the high lift. Just get the modified retainers and you'll be set.
              Matt
              1998 Mystic Teal Camaro M5
