I know where a ls1 ws6 trans am is that is wrecked, with only 57k the car will crank right up the guy only wants around 2 grand for the car complete powertrain. How hard would it be to swap a ls1 into a v6 would there be a lot of stuff you would have to buy even if u had a complete car to part off of. Would u have to rerun all the dash wires for ur gauges and windows and stuff, or can u just like switch computers and it will still run the everything. I knwo i would need new motor mounts is that all what about the drive shaft and transmission i have an at and the car is a at could i use my transmission or would i have to switch, what about the rear end, any advice would help please!!
Ls1 swap to be or not to be?
If the cars are the same year, it's a lot easier. No dash wiring changes are needed. You can probably even put a 99+ in a 99+ without any wiring issues. The 98's stand alone though...\'98 A4 Camaro v6->v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
Originally posted by firebird99ramair6:
what in the hell does do a search mean that dont tell me nothing..
SEARCH
If you have a donor car there should not be much you need to buy!!<b>2000 Firebird </b><br /><i>old setup </i>- Automatic Whisper lid, Borla catback, shift kit w/ V8 servo, 3.42 gears w/ LSD, PI 3000 converter, <br /><br /><i>14.703@90.92, 2.01 60\' </i>(intake and exhaust)<br /><br /><i> new setup </i> swapped over to LS1 413.9rwhp/398.7rwtq<br /><a href=\"http://www.thunderracing.com\" target=\"_blank\">www.thunderracing.com</a>
