Where is the Fuel Pump Inertia Reset Switch.... - FirebirdV6.com/CamaroV6.com Message Board
  • Where is the Fuel Pump Inertia Reset Switch....
    I think its tripped causing no power to the pump.
    1997 Camaro A4<br /> -K&N Filter<br /> -Z28 Catback w/flows<br /> -3.73 gears (not installed yet)<br /> -scu2000<br /> ET(1/4 mile):15.84 at 86.33 (Bone stock)
    Our cars do not have the inertia switches. Fords (trucks in particular) do.
      check your fuel pump voltage lines and earth (ground ) connections . it could be a dodgy earth from the battery ..which is multi strapped to a single earthing terminal on the lefthand side suspension area , under the hood of your car, if it is corroded the ground could be bad. but clean them up ,ad WD40 the connection. aslo check all relays and fuses in line with the fuel pump system . good luck
      British Camaro
      London, UK
        F-body's arent Fords.
        1995 Pontiac Firebird
          Ya know, supposedly your country started the language, but nobody there seems to speak it. ;) ;) J/K :D
          Anyway, check the fuel pump fuse.
