Im stationed overseas, and getting to a dyno is hard...with the mods in my sig block, how much HP (est) am I pushing at the crank?
With my drag races, I can only get a slight estimate, cause track prep has been horrible...best I got with a 3700+ lb car with out the cat, lid and filter on 18" streets was a 16.020, so thats about 215 :(
well i think they are rated at 200 stock so figure 210-225 now probably.
00 GTP<br />98 Camaro v6<br />See, told ya I\'d be rockin another 4th gen :D<br />V6 & V8 tuning available at <a href=\"http://mysite.verizon.net/whenn1/\" target=\"_blank\">http://mysite.verizon.net/whenn1/</a>
