New v6 on the horizon (all aluminum, variable valve timing, etc.) - FirebirdV6.com/CamaroV6.com Message Board
  • New v6 on the horizon (all aluminum, variable valve timing, etc.)
    http://www.ai-online.com/ppp_detail.asp?id=179
    Lots of interesting features:
    Variable valve timing, 4 valves per cylinder
    Aluminum block, aluminum heads, 6 bolt main caps
    Dualstage variable manifold. A valve in the manifold changes the plenum volume available for resonance tuning of the inlet flow path. When the valve is shut, the cylinders feed from two separate plenums. In this mode the system boosts cylinder charging in the low- to midspeed range. At higher engine speeds, the valve opens and the cylinders all feed from a common larger plenum.
    90 percent of the 252 lbs-ft. peak torque is available across a broad operating range, from 1,600 to 5,800 rpm
    GM says the output of the most powerful variant of the new engine family will exceed 370 hp, with torque in excess of 350 lbs.-ft.
    ***** I need to get me some of that... *****
    :D
    \'98 A4 Camaro v6-&gt;v8 conversion, and STS kit next<br />v6: 13.6 Powerdyne, 13.2 150 shot, 13.8 120 shot, 14.3 85 shot, 15.7 stock<br />v8(na): 12.18@113, 392rwhp<br />Moderator on <a href=\"http://www.mtfba.org\" target=\"_blank\">www.mtfba.org</a> and <a href=\"http://www.frrax.com\" target=\"_blank\">www.frrax.com</a> (Road Race & Autocross)<br /><a href=\"http://community.webshots.com/user/johnduncan10\" target=\"_blank\">Car pics</a>, <a href=\"http://www.trscca.com\" target=\"_blank\">TN Region SCCA</a>
    :eek: *drool*
    Up yours Honda :D
    <blockquote>quote:</font><hr>An added benefit of the VVT system is that it allowed for the elimination of the exhaust gas recirculation system, thus reducing weight and complexity.<hr></blockquote>
    Sweet no more crappy EGR
      This was published by autospeed (aussie company) many many moons ago btw. OLD information but neat to hear.
      2002 5-spd NBM Camaro
      Details: www.1lev6.com
        That 350+HP V6 is suppsed to be turbocharged. That is why it has such a high rating.
          Oooooo, can I can I, oh please!!?? :eek:
          K&N Air Filter<br />Magnaflow Exhaust
            Forged steel crank!! And who wanted a 350z?? The motor is going to kick *** !!
            Jeff ..
            1998 Firebird.. Built 3.8 with a 125 shot.. 370rwhp,415rwtq.. stock tune!! sold
            2002 WS6 T/A.. Bolt ins..448rwhp
            2009 G8 GT.. Vararam intake, GXP axleback
            1998 Corvette.. Vararam intake, Ti axleback
            http://www.fquick.com/slow-v6
              what r they going to put that in?
                Question, when is this engine available?
