Help - FirebirdV6.com/CamaroV6.com Message Board
Help
  • Help
    ok as some of you know im in the process of doing an ls1 engine swap
    my car 1998 camaro v6
    donor car 1998 z28 vert
    ok today i looked at the fuse box on both the v6 and the v8
    the v8 has more fueses on the v6 those are dead spaces
    what do i do willk this affect anything i herd that on the v8 the coil packs have 2 fuses and the v6 1 how do i remidy this wire situation
    please help if you can
    and also on the left hand side faceing the engine the throttle cable from the gas pedal goes into a box and comes from there and goes to the tb
    it has 2 wires connected to it my v6 does not have a wire there.....
    and last someone mentioned that i can use my gas take if i get a t bar and run the return line back into the main line is that true????????? please help if you can
