HPtuners Gains - FirebirdV6.com/CamaroV6.com Message Board
HPtuners Gains
  • HPtuners Gains
    Using the bin file I found here, http://www.horist.com/hptuner/ , I programmed a friends 96 camaro with 97pcm. Yesterday I went with him and dynoed and he saw a gain of 12rwhp from that basic tune on a intake exhaust car.
    Don't no if this belongs in advanced tech, but it is pcm related and I figured you guys would be interested in the gains. (He also switched to 93 octane gas over the 87)
    97 polo metallic green v6<br /><a href=\"http://www.cardomain.com/id/tdaddyz\" target=\"_blank\">My Car</a>
    I downloaded the file as well a while back and it is just a "basic" tune. I beleive a lot higher HP numbers will be reached. Not only on a N/A car, but FI as well.
      thats a pretty good gain!
      wanna tune my car? I will be your friend! [img]smile.gif[/img]
        lol if i had the software for your car i'd gladly help.
        oh, and i forgot to add, he gained about 4 or 5lbs or rwtq
          &lt;--- so excited.... my puter goes to them this saturday [img]smile.gif[/img]
            yeah i know, it was like christmas in july when i got the box in [img]smile.gif[/img]
              HPTuners FAQ:
              DO NOT:
              - write a binary that came from another VCM
              http://www.hptuners.com/forum/YaBB.p...num=1086699403
              1. You guys are downloading other files and just straight uploading them to your PCMs?
              2. You believe someones file is going to work on 'your' car cause it did on their car? And also believe the skills of the file owner?
                So your saying it would be better to have someone write it out and then send it to you. Then all you would have to do is write your own file, putting in the numbers they have sent to you. I'm asking this because I have no idea how to tune. I should be getting the Hptuner software at the end of the month. I hope to have a better understanding of how it works after seeing it.
                  The best way is to open up the tables they edited and compare to yours. Use it as a reference. Edit your own binary and only flash that to your PCM.
                    You need to make sure the operating system #'s match up.
                    There is a file on horist' site.. done by a "friend" of mine. :cool: It's a basic tune for a 4.10 car w/exhaust. The car is a tank though and runs on 87 octane so "my friend" couldn't do much with the timing..
                    Make sure that files operating system is the same # as the one on your PCM.
                    Keith - Chicago<br /><a href=\"http://www.hptuners.com\" target=\"_blank\">HP Tuners - PCM Reprogramming</a><br /><a href=\"http://www.dxsoftware.com/magnus/\" target=\"_blank\">97 Firebird V6 to LS1 swap</a><br /><b>V8 9.967@132.78</b> 1.322 60\' NA Heads/Cam<br /><b>V8 10.295@128.48</b> 1.363 60\' NA Cam Only<br /><b>V8 10.987@119.31</b> 1.422 60\' NA Stock Internals<br /><b>V6 13.674@98.22</b> NA<br /><b>V6 12.394@104.91</b> N20 100HP
                      yeah, i just downloaded the file and compared it to my values and changed bits and pieces for mine.
                        hrmph.. I am thinking about going with TSP at this point.. I cant decided..
                          Originally posted by Clark:
                          HPTuners FAQ:
                          DO NOT:
                          I can't speak for T, but I downloaded the file and compared it to my stock tune, corrected for my gears and such, and changed some parameters in my file compared to the one I downloaded, I DID NOT upload the downloaded file to my PCM, I used my stock .bin and edited it accordingly.
                            well I just order the software ,so well see how it goes.
                              cool you have a pwoerdyne too! we can compair notes!
                              [img]smile.gif[/img] kain4567@aol.com if you need any help!
