I'm getting my Upper Intake modified to fit an LT1 throttle body to go along with my new heads and cam. I've run into a problem. I don't know what I should do with the fresh air pipe that runs from the passenger valve cover to the intake elbow. The throttle body will be closer to the front of the car now and the stock air pipe won't fit anymore, and I can't use an LT1 elbow b/c they don't have the fresh air pipe. Some people said use a breather but I don't know what size to use. What would happen if I just blocked the hole and did have any fresh air inlet? Can someone point me in the right direction??
Need help with new Intake Set Up
Ben<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....Tags: None
the lt1 tb has a port on it for the fresh air tube, just modify the tube to fit the tbWolf<br /><a href=\"http://www.cardomain.com/memberpage/249111/7\" target=\"_blank\">95 black t-top camaro</a>,3.4 5 speed,ud pullies,plugs/wires,de-shaft tb & gutted airbox, homemaid short throw shifter
oh i didn't know the tube went to the TB on the LT1 i thought it was supose to goto the elbow like on the 3.4s. ThanksBen<br /><br />1995 White/Black 3.4L<br />As far away from stock as possible<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=288292\" target=\"_blank\">My Site!!!</a><br /><a href=\"http://www.redlinevsix.com\" target=\"_blank\">RedLineV6</a><br />Rebuild and 3.4 T70 Turbo is complete<br />Details to come....
