Block Filler - FirebirdV6.com/CamaroV6.com Message Board
Block Filler
  • Block Filler
    Ok guys, I need to get some block filler, problem is, I have no clue how to put this stuff in. Already been looking at Hardblok, I think that is the stuff I am going with. I am just not real sure where to fill up to, or how much I should use. Another good question would be how much water does the bare block itself actually hold?
    The reason why I am doing this is because of vibrations/strength. With the removal of the balancer, the engine will be a bit too shaky for my liking, especially for the power I plan on acquiring, and it is either put block filler in ($60) or have sleeves installed ($2500+ custom job by Darton). I am sure that no one has tried doing this with a 3.8l, but maybe there are a few mechanics here that might have done it with a V8 small or big block engine. Any info would be appreciated.
    Thanks
    Wes
    1995 Pontiac Firebird
    We've used it in a few engines we've built but they were strictly race engines.
    I don't recommend it for street use because the cylinders will get really hot since no water can get down to the bottom. I'd suggest trying to find a way to run a balancer. Its just going to vibrate itself apart without it, literally.
    <b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
      Won't be driven on the street.... ;)
      So now, back to the question, Wicked, you know how to "install" filler?
      BTW, I meant balancer shaft, not harmonic balancer.
