Sumping Fuel Tank - FirebirdV6.com/CamaroV6.com Message Board
Sumping Fuel Tank
  • Sumping Fuel Tank
    How should i go about this. i have no idea where to start besides drain the fuel and pull the old fuel pump. i want to do this with the tank on the vehicle. how should i make the sump for it and what not. if any one has ever done this your insight would be greatly appreciated.
    <a href=\"http://www.geocities.com/hemigtx001\" target=\"_blank\">http://www.geocities.com/hemigtx001</a> <br /> <a href=\"http://www.geocities.com/hemigtx001/Firebird_Index.html\" target=\"_blank\">http://www.geocities.com/hemigtx001/Firebird_Index.html</a> <br />1993 3.4L firebird<br />mods-flowmaster 80 series, removed cat. K&N FIPK. custom ram air ducts to filter.<br />Completed Engine Swap.
    So.. I haven't added a sump.
    I wonder if someone sells the swinging pickup/tank like found in some 1le cars or race tanks that come with a sump?
    I'm thinking of adding a surge tank that is fed by the intank pump. One outlet (top) of this surge tank returns to the gas tank the other (bottom) feeds an inline pump to the fuel rail. I'm getting this idea and (using the tank) from how Ford set up some of their first fuel injected Vans. I would guess that this surge tank holds about 2 cups of fuel.
      This is the setup that I am running. You will have to remove the fuel tank to get these welded in.
      http://www.competitionengineering.co...?CatCode=10070
        i gots questions. how long did it take u to get that tank out, cause i know its going to be a PITA and a half. and did you reuise the brackets?
        and how much does that part cost, and where can i get it?
          The tank isn't too hard to get out really. It makes things a lot easier if you have 2 people dropping it and putting it back in. You can reuse the straps as long as you don't bent them out of shape too bad.
          Drop me an E-mail about where to get the part.
            okay now another question is which welder to use. ill drop you an email and ask you more questions via email. as to how to remove it if i really ahve to remove everything theys ay you do.
              i was under the car today trying to finish off removing the LCA's and they are frozen so imma have to cut them off or get someone to bring over an impact wrench or go buy one, but any way i was looking at where the fuel tank is, and the bottom and rear of it is right above the exhaust, im not sure there will be enough clearance for me to sump it, if you got photos that would be great so i can get an idea what you did and maybe that would help me more
              im also thinking about just doing it the way someone once suggested by removing hte old fuel pump from the tank and running a hose down to the bottom if i was to do this i would be using this http://www.howeracing.com/FuelOilSys...FuelPickUp.htm will this work, or am i going to have to do the sump?
              i found out from the company that this will work, but they arent sure how well. i just wanna make sure that it wont fry my fuel pump. so if any one knows that be great if you let me kno.
              [ August 26, 2004, 12:10 PM: Message edited by: wasjo6431 ]
