Rebuild complete BUT...... - FirebirdV6.com/CamaroV6.com Message Board
  • Rebuild complete BUT......
    As it says i have finished rebuilding my engine completly for a list check out my site bnut about 160 Miles after the rebuild The F-ING valve spring broke in half :mad: :eek: I mean what the hell kinda **** is that i purchased them from intense and I am lucky the valve didnt fall back into the cylinder so Theres more work now CRAP :mad:
    sorry dude, that sucks
    2000 Navy Blue T-top Camaro A4<br />TSP Rumbler <br />Carsound Hi-flo Cat<br />!MAF screen<br />Whisper lid<br />HPP3
      ide be quite butt hurt.
        Intense racing is sending me another 130LB spring next day air so i have no complaints whatsoever with intense and would highly recomend them for prompt service and quality parts my list after internal rebuild is this:
        complete balance of rods, pistons, crank, harmonic Balancer, and flywheel.
        Clevite 77 main bearings
        Clevite 77 Rod Bearings
        Clevite 77 Cam Bearings
        Victor Reinz hi-po Gaskets
        Hastings piston rings
        polished stock crankshaft
        Removed balancer Shaft
        Intense stage 2 Cam
        (duration @ .050": 222º/224º, lobe lifts: .337"/.327", valve lifts with 1.60:1 rocker arms: .539"/.523", lobe separation angle: 112º, intake centerline: 108º )
        Comp Cams OE-R roller lifters
        Intense High Performance hardened lightweight Pushrods
        (425 grams per set of twelve .049" thick 4130 seamless chrome moly one-piece)
        Comp Cams High load 130LB valve springs
        installed load is 130 pounds at 1.800", 150 pounds at 1.720", and 318 pounds at 1.200".
        Coil bind height is 1.080".
        Outside diameter is 1.290"/1.060" and inside diameter is .885"/.656".
        Comp Cams Steel Valve spring retainers
        Comp Cams Hi Po Valve keepers
        Intense 80 PSI oil pressure Kit
        Roller Master Single roller Timing chain
        Extremely Port and Polished heads with three angle valve job and bronze guide liners
        Port and polished upper and lower intake manifolds
        Port and polished Throttle Body
          Nice setup, top end looks like it won't need much more. What else do you plan on doing to the engine? You plan on FI or NO2?
          1995 Pontiac Firebird
            Yeah FI eventually but for now Nitrous Everything should hold up for alot of nitrous. engine should spin about 7500 rpm so ill prolly get the hp tuners stuff. thats not all my mods i do have others on my site. the pistons and rods will hold up really well so i am not gonna replace those with lighter or stonger ones i cant think of anything else i need besides its already done just that darn spring
              7500 on stock rods? Good luck I guess. You should run a good time if it holds up. Maybe 12s.
                stock rods arent really that bad it is is the bearings and what not that hold evrything together the stock rods shopuldnt stretch at that many rpms
                  How much did all those parts cost you? Did you assemble it all yourself? I got a block, heads, intakes, and TB lying around ready to make my own rebuild.
                    i put everything together but the bottom end i had all the balance hone and line vboring and stuff done for $750 then the parts were about $1700 for everything i did my own heads and manifold but took the heads for a bronze guide liner and 3 angle job so total was prolly around $3000
                      I wouldn't worry about the rods stretching, I would worry about them breaking. Depending on what shot of nitrous you plan on doing and how much boost you plan on running in conjunction with that, those rods may not hold at 7500 rpm. ;)
                        I totally agree about nitrous or FI at 7500 rpm i was talking about n/a 7500 rev which i beleive it can handle altough i have to dyno to see where my power is it all depends where i rev too
