Hey whats up I would like to know how much horsepower i can see from hp tuners on a moded internal engine such as mine check out my specs and also new pics of my engine at my site
My new engine programming
I'm don't want to guess, but lets just say quite a bit.
I don't think seeing a gain of 25 HP on a stock engine, with bolt-ons is impossible, w/ a built engine I would THINK at LEAST twice that especially if the cam and such throws things off a bit.
[ September 01, 2004, 10:00 AM: Message edited by: Nachius ]
It really depends on your current engine configuration and how out of wack your current tune is? It will vary from engine to engine. I think i read somebody gained 12HP on stock engine. So you could expect more then that on a modded engine assuming your tuning will be off more then a stock engine. I dont have any hands on experience with the program but it looks to be a very solid programming tool for our 3.8's. I wish this was available when i had my built v6.
for those of you wanting a mod list i would tell you to look at my site but im gonna post them again.
Internal Engine
complete balance of rods, pistons, crank, harmonic Balancer, and flywheel.
Clevite 77 main bearings
Clevite 77 Rod Bearings
Clevite 77 Cam Bearings
Victor Reinz hi-po Gaskets
Hastings piston rings
polished stock crankshaft
Removed balancer Shaft
Intense stage 2 Cam
(duration @ .050": 222º/224º, lobe lifts: .337"/.327", valve lifts with 1.60:1 rocker arms: .539"/.523", lobe separation angle: 112º, intake centerline: 108º )
Comp Cams OE-R roller lifters
Intense High Performance hardened lightweight Pushrods
(425 grams per set of twelve .049" thick 4130 seamless chrome moly one-piece)
Comp Cams High load 130LB valve springs
installed load is 130 pounds at 1.800", 150 pounds at 1.720", and 318 pounds at 1.200".
Coil bind height is 1.080".
Outside diameter is 1.290"/1.060" and inside diameter is .885"/.656".
Comp Cams Steel Valve spring retainers
Comp Cams Hi Po Valve keepers
Intense 80 PSI oil pressure Kit
Roller Master Single roller Timing chain
Extremely Port and Polished heads with three angle valve job and bronze guide liners
Port and polished upper and lower intake manifolds
Port and polished Throttle Body
Induction
Whisper air induction lid
Fast toys Ram air kit
K&N Air Filter
Exhaust
2.5" piping
No Cat
Custom made cut-out
Dynomax superturbo 2.5" In Dual 2.5" Out
Drivetrain
1997 A4 transmission
Billet aluminum high performance servo
LNJ 3000 Rpm custom high stall torque converter
TransGo Stage 3 Shift kit
Energy Suspension poly-urethane transmission mount
Take Off LSD
3.73 rear end gears
Customized Tranny Crossmember
Fuel
Walbro 255 Lph Pump
Nitrous works 25-100 wet shot
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.5 hours ago
Hello every one, ozzy here ive been looking at this page for weeks now finally joined. So my question is why is it that every turbo build forum just ends...2 days ago
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....1 week ago
