i have white smoke come out when i start my car but it stops as soon after started . it puffs and thats it. its not constant what do i do or what is it . is it something to worry about???
please help white smoke
No.... lol Its just condensation/evaporation.2001 V6 Camaro - VTEC Badged, Abbott Racing Heads Sticker, and Loud A$$ Exhaust<br /><br /><b>BUILT NOT BOUGHT</b><br /><br />14.0 @ 96.44 MPH (Street Tires, Before Tranny)<br /><br /> <a href=\"http://members.cardomain.com/6pakcamaro54\" target=\"_blank\">http://members.cardomain.com/6pakcamaro54</a>
If it is the valve stem seals, no need to rush to get it fixed. What happens is when the car is cold the seals let a little oil leak by, but after warming up, the seals expand the the leak goes away. No real harm.
To take car of it you will need to get new valve stem seals - not a cheap repair at the shop.
It will only smoke a lot on warm startups because the oil is thinned out from being warm, it then is able to squeek by a seal and smoke. It burns oil all the time, but on a startup more oil is built up so it is very noticable.
You need new valve stem seals, its not the easiest repair.
You have to put air in the cylinders to hold the valves while you remove the valve springs and replace the seals.
The oil will very quickly start to buildup on the valves, heads, headers, etc. It can make a real problem. It will also foul o2 sensors.1997 Chevrolet Camaro v6 - 13.8@104MPH
1997 Dodge Viper GTS
Oil shouldnt be white smoke? Oil's blue or atleast with a blue tint like you said earlier.
Valve Seals should just give a puff/cloud and be done.2001 V6 Camaro - VTEC Badged, Abbott Racing Heads Sticker, and Loud A$$ Exhaust<br /><br /><b>BUILT NOT BOUGHT</b><br /><br />14.0 @ 96.44 MPH (Street Tires, Before Tranny)<br /><br /> <a href=\"http://members.cardomain.com/6pakcamaro54\" target=\"_blank\">http://members.cardomain.com/6pakcamaro54</a>
