yes i finally did it i installed my 1.9 xstreems rockers will ls6 spring and boy can u feel a diffrence i love them. took me half of a day to do it but it worth it though i did break something. i broke my oil sending unit stupid me left my wrench on the crank and when i put air in the cylinder i forgot that it was going to spin and it spun the wrench which broke my sending unit :eek: but it only cost me 32 bucks to fix so no biggy here are some pick my rockers and springs in stalled. http://photobucket.com/albums/d33/bg...h_DSC00753.jpg http://photobucket.com/albums/d33/bg...h_DSC00752.jpg
2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
I wish the pics where bigger, they from what i see it looks awsome. What do you mean you can feel the diffrence, does the engine run smoother, do you notice better throttle response? Let me know, id really like to change mine out to high proformace.
im sorry AZ3.8CAMARO i thought u where talking about something else i thought u where talking about the vale caps for my springs my bad u ment the retaining bolts right? if u are no i did not use stock once i use the once the intence gave me with the rockers
I AM talking about the "caps" on top of the springs. You MUST run ls1 or ls6 retainers with the ls1-ls6 springs. It is not a commonly known fact, and it has been giving MANY of us problems. just an FYI.
1997 Dodge Viper GTS
