what web site you get them from? just wondering i've only found some for 499.99 but for 369 for rockers and 100 for springs let me know thanks
finally installed my 1.9 and ls6 springs
AZ3.8CAMARO thanks for the tip but but im running stock caps on them and it hasnt bin giving me any problems latey. hers the sit where i got them
http://www.intense-racing.com/Mercha...egory_Code=HCV2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
To give further info about what AZ is talking about. Here is his thread where this is discussed. [img]smile.gif[/img]
http://www.camarov6.com/ubb/ultimate...=003538#00000592 S10 3800 A4(96)<br />1/4: 14.374 @ 92.25 w/ 1.976 60\'<br />Turbo and 12\'s Coming Soon!
hey everyone i talk to scott from intencse and he told me this:( No. LS6 valvesprings work just fine with stock valvespring retainers. They both measure exactly 0.645" ID in case you want to verify this yourself. We've installed these on hundreds of cars without issue.)
Hope this helps.
Scott
so what do u guys think should i still do the retainers?2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
if so what type should i get ls1 retainers or ls6 retainers which would work better for me thanks2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
The diameter has nothing to do with it. The issue is the install height with the different retainers.Matt
1998 Mystic Teal Camaro M5
Hope this helps.
Scott
Ask scott to look up the stock install height on an LS6 spring. Now have him look up the v6 spring. Its .100" off. The max lift on an LS6 spring when installed .100" lower than it is designed to work at is .500" and not .600" like they think it is.1997 Chevrolet Camaro v6 - 13.8@104MPH
1997 Dodge Viper GTS
so what type of retainers should i get ls1 or ls6? thanks for the help guys2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
so what type of retainers should i get ls1 or ls6? thanks for the help guys92 S10 3800 A4(96)<br />1/4: 14.374 @ 92.25 w/ 1.976 60\'<br />Turbo and 12\'s Coming Soon!
cool im get my retainers today thanks guys for let me know about this [img]graemlins/bowdown.gif[/img]2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
need help finding a balancer and a replacement balancer bolt. im at a lost after confusing myself researching.4 weeks ago
