ok as someo f you know im doing an engine swap currently. Im putting in a carb'ed 350 with a TH350 trans. im wondering if my stock guages are still going to work. or do i need to buy new ones. i dont mind buying new ones. so if its the easiest way to go ill go that way.
Guage Setup
Guage Setup
<a href=\"http://www.geocities.com/hemigtx001\" target=\"_blank\">http://www.geocities.com/hemigtx001</a> <br /> <a href=\"http://www.geocities.com/hemigtx001/Firebird_Index.html\" target=\"_blank\">http://www.geocities.com/hemigtx001/Firebird_Index.html</a> <br />1993 3.4L firebird<br />mods-flowmaster 80 series, removed cat. K&N FIPK. custom ram air ducts to filter.<br />Completed Engine Swap.Tags: None
