Which cam of these? - FirebirdV6.com/CamaroV6.com Message Board
Which cam of these?
  • Which cam of these?
    Ok im getting one of these cams, but i need help deciding. i want a lower powerband, like 1500-4500. i dont want to start making power way up there. this is the first cam
    Intake
    Exhaust
    Duration @ .050
    226°
    236°
    Valve Lift w/1.5 Rockers
    .463
    .474
    Lobe Seperation Angle: 112° LSA
    and heres the second
    Intake
    Exhaust
    Duration @ .050
    228°
    228°
    Valve Lift w.1.5 Rockers
    .465
    .465
    Lobe Seperation Angle: 110°
    Intake Centerline: 106°
    this is gonna be a street driven 3.4, and i want good power for the street.
    1997 Camaro 15.3@91 with a 2.35 60ft-B&M Ripper, SLP Knob, SLP CAI, LT1 DS, EBC Pads. 1994 Camaro(Sadly Sold)-Hi flow cat, custom flowmaster american thunder cat back, KN FIPK, Accel wires, Plat plugs, 160 thermo, Fastchip, Pacesetters.
    They are both BIG cams, but the second one would be a little better for the street. It is the one I am running and I am very happy with it. Are you going to get a mild port & polish job done on the heads with the cam? If so, it will obviously bring out the power a lot more.
      im not gettin the heads port and polished right now, i am in the future, but funds are limited. how does teh car sound at idle? and what kind of power does it make, and what is the powerband?
        y did you use the term "mild" viper, should one only port mildly with that cam, or should they shave as much crap out as possible?
          You should get at least a mild job done if anything (at least smooth the runners) so that the air flows better. If you can though, shave the **** out of them and go to town.
          With the second cam, the car lopes a lot at idle. Be prepared to get an AFPR and some hotter spark plugs. Powerband is pretty high and very strong.
            k, thanks. i'm having them go to town on my heads!!!
              2nd one is better IMO.
