350 Carb into 95 3.4l v6 - FirebirdV6.com/CamaroV6.com Message Board
  • 350 Carb into 95 3.4l v6
    I am going to swap a 350 carb motor into my 95 v6 I was windering if anyone has done this and if there is a distribitor I could use that would not hit the firewall
    Yes you can do it, its been done many times. Get one of the smaller diameter distributors and cut the cowl out. With it set up like that you can pull it out w/o pulling the motor.
    <b>Black</b> 1998 Pontiac <i>Firebird</i> A-4 swap<br />271.4rwhp/259.4rwtq NA<br />13.30@102.44 <br /><a href=\"http://www.freewebs.com/wickedsix98\" target=\"_blank\">www.freewebs.com/wickedsix98</a>
      I figured that but i was not 4 sure. Do you know of any web sites where someone has done this kind of swap?
