Tips on Leaning out the motor-need help! - FirebirdV6.com/CamaroV6.com Message Board
  • Tips on Leaning out the motor-need help!
    I have a 96 3.8 with cold air kit, and full custom exhaust. I have had the cat off for 2 years now. I took apart the throttle body to mill it out and increase the cc's its flowing. Inside the upper intake their is what looks like an excess fuel and carbon build up all over it. Need help, Im not sure what it is, or why its there. If my engine is not utilizing all of the fuel, what ways can I change things to do so. Hotter plugs? Please send me some feed back. Thanks.
    96 RS<br />SLP CAI<br />Removed MAF screen<br />Extensive throttle body milling.<br />5 Speed B&M ripper<br />3.73 posi<br />1.5\" lowering kit<br />Superlight white aluminum rims<br />245 eagle GSC\'s<br />3\" SS stainless exhaust<br />Cat Cut out<br />30th anniversary paint scheme.
    Don't get hotter plugs. Get one of those s-afc plug-in computers and use that to lean out the mixture.
    2001 Arctic White Firebird<br />T-Tops, 3.42 rear gear stock<br />Mods:K&N Air Filter,Whisper Air Induction Lid, maf screen removed, raised air box, Kumho Ecsta 712 255-50-ZR16 tires, BMR stb<br />Mods not installed yet: FTRA, SLP Lsd/Differential cover<br />Near Future Mods: HPP3, GMMG 3\" Exhaust , 1LE Swaybars, Transgo Shift Kit, MSD-DIS-4 w/ Accel Coil-Packs, Turquoise Blue Neon Underbody Kit, BMR Adj. LCA\'s, G2 Sfc\'s & V-braces, Pacesetter headers
      has anyone gotten an SAFC to work on a fbody yet?
      R.I.P \'99 Firebird, you will be missed<p>New toy - 2001 GSXR-750, Yoshimura Exhaust, Power Commander, Rebuilt Airbox
        The carbon in the intake is probably from the EGR... I don't think its the PCV but you could check that as well..
        If you want to lean the car out, MAFT works best.. if you want to lean it out and add timing advance, then get the MAFT+.
        If you don't want more carbon buildup, then you have to block of the EGR.. that will set SES codes though.
        - Keith
          Just a quick ? What does the EGR do? if it isn't working, or not their does it hurt our cars at all?
          1996 Y87 Camaro, 175.0 rwhp, 211.6 rwtq.....1/4 15.500@88.54 &lt;----- Needs work!!<br />-CAI, Custom bent S-Pipe, LS1 I-Pipe, Flowmaster 80 series, !MAF, manual fan switch, relocated trunk pop switch, 180 degree t-stat, More to come!<br /> <a href=\"http://camaro.wbisolutions.com\" target=\"_blank\">http://camaro.wbisolutions.com</a> <p>WANTED!!! Naked and handcuffed!
            EGR is Exhauts Gas Recirculation.. it helps emissions I believe. If its not there, it won't hurt the performance of the car.. but it won't help the WOT performance either if you remove it.. its mostly a cruise thing that is disabled during idle and WOT.
            If you remove it you have to fab up some blockoff plates to plug the holes on the intake and exhaust manifold
              cool thanks!
                hey magnus, is the egr a restriction? would more air flow in and create more power,i was just curious. [img]graemlins/dunce.gif[/img]
                96 wht. firebird 5sd. rk sport headers,3in.catco, spintech catback,CAI,FRA,3.42/lsd 180*t-stat, centerforce dual friction clutch, ls1 driveshaft, polyurethane trans. mount.<br />01 blk. z28 m6, borla exht, lid, k<br />+n, sfc., chrome 18in. y2k c5 wheels.
                  Nope.. not at all.
